No Start
Unit engine will crank over but will not start. Verified correct / on time spark. Not getting correct / any fuel. Unit will start, run then die on sniff of ether. Getting only 6.7 (& soemtimes 0) volts to LPG regulator & trim valve. Tested / checked / verified all fuses, relays & ECU module correct.
  • Posted 4 Oct 2017 07:50
  • By SteveS1
  • joined 4 Oct'17 - 3 messages
Checked distributor wiring. Only 2 wires going into dist. & both appeared in good condition with no open circuits present upon visual inspection. Unit had battery voltage to regulator & injector today upon cranking engine over. Got engine to start with sniff of ether. Ran good at high idle. Runs rough at low idle & close to stalling. Shut engine off. Attempt to re start. Will not start unless ether it. Attempt to adjust fuel trim screw on regulator all the way in & out with engine running at low idle. Had no effect on runability. Drove unit. Unit runs excellent with plenty of power from low to max. RPM's. Any additional tips could give me? What is the resistor for next to the ecu?
  • Posted 6 Oct 2017 08:25
  • By SteveS1
I'll test the circuit. Thanks a bunch for the fast response!
  • Posted 4 Oct 2017 10:09
  • By SteveS1
Some of these had a problem with the "tach signal" wire that goes from the distributor to the ECU that sends a signal that the distributor is turning and then the ECU turns on the LPG. I think it is a black wire that is shielded. They break right near where it goes in the distributor.
  • Posted 4 Oct 2017 08:52
Philadephia, PA, United States
Chandler, United States
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
