No start turns over
Our 7FGCU20 will not start. Full tank in proper position for liquid pickup. Turns over great. Compression is 150 each cylinder. All plugs are sparking. Unit will start on ether. I pulled the injector and I can feel it pulsing puffs of propane when cranking. The large low pressure hose has pressure when cranking. Not sure what do about this. Any tips?
  • Posted 11 May 2021 05:43
  • By Joe_M
  • joined 11 May'21 - 6 messages
There is a vacuum hose that goes from the mixer at the bottom by the governor to the back side of the regulator. I found that if I remove this hose it will start and run pretty close to perfect. If I reconnect the vacuum hose it instantly dies. If it is connected it will not start. (BTW took out the drain and nothing came out) The regulator is an Asian type c also tagged 30F80.
  • Posted 3 Jun 2021 09:54
  • Modified 3 Jun 2021 09:55 by poster
  • By Joe_M
Truck has Asian propane converter primary seat is stuck closed must takeoff truck and rebuild and clean or get new converter never had luck on draining
  • Posted 16 May 2021 07:10
  • By Scott_
Scott
Never starts on propane Will only start on ether but I only give it enough to run for a few seconds.
  • Posted 14 May 2021 04:20
  • By Joe_M
Is it just the initial start that is difficult? It starts fine after the unit has been warmed up and in operation for a while? If so, the regulator is likely full of wax and needs to be drained.
  • Posted 14 May 2021 02:11
  • By TripleB
  • joined 1 Aug'12 - 6 messages
  • Alberta, Canada
On which hose? The large hose or the injector hose?
  • Posted 12 May 2021 02:25
  • By Joe_M
If you have a gauge, the lp pressure should be in the 1.5-5psi range
  • Posted 12 May 2021 02:08
  • By Triggs
No it's not freezing. Do you know the procedure to test the regulator?
  • Posted 12 May 2021 00:56
  • By Joe_M
I'm assuming the regulator isn't freezing up? I would clean the throttle plate first
  • Posted 12 May 2021 00:34
  • By Triggs
Ice 28INCH-AUTO-SCRUBBER
USD8,350
Maxlion FB30LI
Bolzoni SpA (Group HQ)
