No spark
Hyster H65XM 3.0 GM no spark from coil wire, distributor module, pick up coil and crank sensor have been replaced. Can get spark and engine will start and run for about 15 seconds if 4 wire plug is disconnected from distributor. Manual mays that is a bad pick up coil so I replace it with another coil but no change
  • Posted 31 Jan 2024 15:00
  • By terry_c
  • joined 26 Feb'12 - 21 messages
  • Oregon, United States
Am no expert on this but how this works is the two plug on the distributor is for base timing as the engine turns and reaches about 400rpms the engine starts then the 4pins side of the module takes over and sends a signal to the computer to control the timing of the engine. They call this the est side if there is a problem on the distributor module or the wiring going to the computer it will not stay running check the 4pin wiring and the module if it all checks out it is possible you have a ecm problem.
  • Posted 2 Feb 2024 13:16
  • By Scott_
Scott
Michel Denis Michel Denis
