No spark
I have change the following
Distributor assembly
Igniter
Computer box
Before I changed any of those parts I found 5 wires that were cut due to chafeing, this wire loom runs along side the value cover. I fixed the broken wires and still no spark. Then I had change parts list above. STILL NO SPARK.
Cap and rotor wires plugs are new. Fuses and relays are good. Can anybody help.
  • Posted 11 Feb 2020 12:26
  • By Stephen_Ladeau
  • joined 11 Feb'20 - 4 messages
Stephen ladeau
Have you replaced the coil?
  • Posted 16 May 2024 00:24
  • By Hemi
  • joined 9 Aug'22 - 13 messages
  • New Mexico, United States
Humberto Fernandez
Main harness.. had the same issue
  • Posted 15 May 2024 14:14
  • By Wattscrowntech
  • joined 7 May'24 - 4 messages
Daniel
I work in the day time but I will see if we have a tarp to throw over the lift, thanks I will get back to you
  • Posted 13 Feb 2020 01:05
  • By Stephen_Ladeau
Stephen ladeau
at night in a dark area, crank the engine over and look for any jumping current in and around the engine compartment
  • Posted 13 Feb 2020 01:02
  • By Africa
  • joined 11 Oct'17 - 11 messages
  • Eastern Cape, South Africa
Let us lighten your load
Thanks for responding. Battery voltage is good I have the charger hooked up on 12v low for testing, I have now changed ignition switch and the wire harness for the engine side, and fuel solenoid behind the fuel regulator. Earth grounds are good. Any more suggestions please.
  • Posted 13 Feb 2020 00:57
  • By Stephen_Ladeau
Stephen ladeau
Check the battery voltage is correct. Check the ignition switch, check that you have earth, check concernunity in the chaffed wires? Please let me know what you find?
  • Posted 12 Feb 2020 07:52
  • By Africa
Tampa Florida, United States
May CapEx Index falls Washington, DC, United States
SMV (Konecranes) 4545CCX5
Mitsubishi FD200
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
