No Reach Function
I have a reach truck that the reach function would intermittently cut in and out. After a time, it has cut out all together and will not reach or retract. Swapped known good coil drivers, reach solenoid, handle and there was no change.
  • Posted 19 Apr 2018 04:39
  • By kyle
  • joined 16 Mar'18 - 5 messages
I would verify you have voltage to your solenoids through your over mast cable and the small cable located inside the reach assembly. You probably have a broken wire.
  • Posted 5 May 2018 13:23
  • By Service_T
  • joined 5 May'18 - 91 messages
  • Kansas, United States
