no power
Unit will not power up. No BDi display. Hour meter is working and i check the wire harness that plugs in the back of the hour meter/ service panel and the fuse. Battery voltage is 24.I have checked both disconnect switches. The diode on the line contractor test ok. Line contactor ohms are 55. When i install the handset the code is COM (communication error). I have key on power to the controller. Anything else to check before I replace the controller? Fuses on the control panel test ok.
  • Posted 19 Aug 2016 09:41
  • By glock01
  • joined 26 Apr'09 - 19 messages
  • Idaho, United States
No, l/h control pod is the one with the keyswitch, r/h control pod is the one with the twist grip.
  • Posted 26 Aug 2016 10:09
  • By techno_nz
  • Canterbury, New Zealand
If ed contactor is not pulling in, and there is voltage to controller, ed -ve is from mrc1, +ve is after both emergency stop swtiches,
  • Posted 23 Aug 2016 08:07
  • By southernviking
  • joined 25 Mar'13 - 43 messages
  • South Island, New Zealand
Is the l/h control pod the panel where you plug in the battery charger?
  • Posted 20 Aug 2016 07:11
  • By glock01
I would pull the l/h control pod off and check the connector is fully inserted and none of the terminals are loose. It should show a CAN fault but its worth a look before replacing the main controller.
  • Posted 19 Aug 2016 16:58
  • By techno_nz
Terberg YT222
SMV (Konecranes) 20-1200B
Sue Tomic Sue Tomic
