No power
Serial # 9A116204
When turning machine will get code 04, 03, 02. when driving straight no codes and everything o.k. any ideas?
Now have now power to key switch, no horn, no dash display, can anyone help me locate the fuses on this machine....?
Have also found these codes
Slave-57,66,68,82,118,65
master-112,110,12,68,150,118,82
any help would be greatly appreciated!
Thanks in advance!
  • Posted 11 Jun 2016 05:14
  • Modified 11 Jun 2016 06:10 by poster
  • By JAYS
  • joined 16 Apr'16 - 26 messages
  • Iowa, United States
Fault codes 4, 3 and 2 are for direction selected before acceleration or parking brake on when driving. Make sure wires to direction select switches in column are ok then check your key switch and battery power. Should not drop below 32 volts under load or you have bad battery. Codes in controllers could be anything it all depends on when they happen according to hour meter now.
  • Posted 12 Jun 2016 12:12
  • By popeye
Briefs United States
