No power to front right drive wheel.
Had power and ran fine when parked for the winter, it was parked outside with a tarp over it. Wheel was slightly froze up but now can free spin the front right motor and wheel however I'm not getting any power to it. Have forward and reverse to the left front drive wheel no issues. Is there a switch with separate contacts for both sides to operate or a fuse that cuts off one side or the other? Thanks
  • Posted 26 Apr 2023 21:22
  • By Joshua_Brack
  • joined 26 Apr'23 - 1 message
  • Missouri, United States
you got to make it to make it,
In addition to steer switches, there is a fuse for each drive motor. Also, make sure that your motor brushes are not seized up inside the motor brush block holder. This is common with the RC3000 due to the age of the truck. Also, the motor armature may need cleaning with a comm stone.
  • Posted 5 Jun 2023 11:50
  • By 1CrownTech
  • Washington, United States
There are 2 switches on steering turntable that controls which drive motors operate depending on which way they are turned. Also 2 power fuses for l/s drive motor and r/s drive motor. Probably 175 Amp fuses. Could be as low as 140 Amp. If contactor pulls in then check fuses, contactor condition, cabling or motor itself. If the contactor does not pull in, check switches.
  • Posted 27 Apr 2023 19:54
  • By Walter_Rautter
  • joined 17 Oct'19 - 1 message
Toyota 02-8FD25
Toyota 02-8FD30
