no number in the manual
hi i have a wave 60 and i t is presenting me whit a problem, walk a few meters and stop suddenly. show me the code 284 and 349....I looked for them in the manual but don't appear
I already deleted the error, and it does the same to me and the wave is new it has only been in the factory for two weeks
thanksfor all
hugo gil
  • Posted 24 Aug 2024 05:15
  • By gilos
  • joined 24 Aug'24 - 3 messages
  • Mexico
hugo gil muniz
Yeah unfortunately crown does not have any branches in Mexico so you are dealing with a 3rd party dealer, some of which are a pain to work with especially outside of the US. I'd call the closest branch even if it is in the US as they can light a fire under the dealer to get them to take care of this.
  • Posted 3 Sep 2024 23:47
  • By DyslexicNerd_01
  • Wisconsin, United States
Si muchas gracias por la ayuda ya me comunique con crown... Pero no tienen tiempo ni dan una fecha de su visita....
Muy mal el servicio...
Saludos
Ing HugoGil
Littoral Translation:
Yes, thank you very much for the help, I have already contacted crown... But they do not have time or give a date for their visit....
Very bad service...
Please use English
  • Posted 31 Aug 2024 07:17
  • Modified 31 Aug 2024 09:35 by administrator
  • By gilos
  • Mexico
hugo gil muniz
It sounds like the access 3 memory keeps reseting or you have a line coil/brake drive short. Typically when it throws codes that don't exist something is typically wrong with one of the modules. Because it is happening during drive, and code 349 I'd guess the access 3 is having issues possibly with its memory causing it to disable all functions, reset memory and then once the code is cleared act normal.
If this is a brand new lift (less than 365 days old) contact your local crown dealer as this is a factory warranty. Labor and parts should be covered to fix this issue. Replacing modules can get very expensive.
  • Posted 31 Aug 2024 04:54
