no lift in lockout
no lift operation seams to be in lift lockout horn sounds when lift up pressed. is low battery charge only thing to cause this?
  • Posted 17 Dec 2008 21:12
  • By rick_o
  • joined 7 Nov'08 - 33 messages
not _ONLY_ thing, but far most likely thing.. and if the battery is low, you should fix that part first anyway, no matter what caused the problem..
  • Posted 17 Dec 2008 21:27
Lithium Storage
Leading China-based developer and manufacturer of Industrial Lithium Batteries.
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
