No Hydraulic Function on E45XM
No hydraulic function on E45XM; serial number F108V14567V
- error code - 145
Suggestions?
  • Posted 13 Mar 2017 03:08
  • By davev
  • joined 13 Mar'17 - 1 message
  • Michigan, United States
if you have a handyman tester use it to check the #2 rec and use a vom and check the snubbers on the spider block first.
The 2 rec's are notorious for causing issues like this, they will go out before the #1 does usually, this is why it is listed for the possible cause first before the 1rec.
When you use the handyman there is a test mode for hi voltage bleed thru , do that test and if you see the light light or even blip then replace the scr.
just make sure you double check all the connections before replacing any.
  • Posted 13 Mar 2017 14:05
  • Modified 13 Mar 2017 14:06 by poster
Indication of Fault The hydraulic pump control does not operate.
Possible Cause Malfunction of SCR 2 circuit.
Check for a short circuit across SCR 2.
Check for a short circuit across the suppressor for SCR 2.
Check for an open circuit across SCR 2 or an open gate lead to SCR 2.
Malfunction of SCR 1 circuit.
Check for an open circuit or loose connections between SCR 1 and PZ8 (white/blue wire).
Check for an open circuit or loose connections between SCR 1 and D3 suppressor and PZ9 (blue wire).
Malfunction of SCR 1.
An open or bad gate circuit to SCR 1. No easy test is possible. Replace SCR 1 after the other checks have been done and no other problem is found.
  • Posted 13 Mar 2017 05:22
  • By kevin_t
SCR 1 in the hydraulic pump controller does not go to ON correctly.
  • Posted 13 Mar 2017 05:21
  • By kevin_t
edition #1237 - 3 July 2025
