No Hydraulic Function on E45XM
No hydraulic function on E45XM; serial number F108V14567V
- error code - 145
Suggestions?
  • Posted 13 Mar 2017 03:08
  • By davev
  • joined 13 Mar'17 - 1 message
  • Michigan, United States
if you have a handyman tester use it to check the #2 rec and use a vom and check the snubbers on the spider block first.
The 2 rec's are notorious for causing issues like this, they will go out before the #1 does usually, this is why it is listed for the possible cause first before the 1rec.
When you use the handyman there is a test mode for hi voltage bleed thru , do that test and if you see the light light or even blip then replace the scr.
just make sure you double check all the connections before replacing any.
  • Posted 13 Mar 2017 14:05
  • Modified 13 Mar 2017 14:06 by poster
Indication of Fault The hydraulic pump control does not operate.
Possible Cause Malfunction of SCR 2 circuit.
Check for a short circuit across SCR 2.
Check for a short circuit across the suppressor for SCR 2.
Check for an open circuit across SCR 2 or an open gate lead to SCR 2.
Malfunction of SCR 1 circuit.
Check for an open circuit or loose connections between SCR 1 and PZ8 (white/blue wire).
Check for an open circuit or loose connections between SCR 1 and D3 suppressor and PZ9 (blue wire).
Malfunction of SCR 1.
An open or bad gate circuit to SCR 1. No easy test is possible. Replace SCR 1 after the other checks have been done and no other problem is found.
  • Posted 13 Mar 2017 05:22
  • By kevin_t
SCR 1 in the hydraulic pump controller does not go to ON correctly.
  • Posted 13 Mar 2017 05:21
  • By kevin_t
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
