No high speed lift
As far as I know this truck has never had high speed lift. The M3 motor looks like new. If you ground the P2 contactor the motor and pump will run. No ground found when backprobing the Access2. The values for the lift handle are good. The P2 is turned on in the settings but output tests are not available. I've tried another Access2. I thought there might some safety issue but no warnings or codes appear.
2007 Crown RR5220-45 1A316996
  • Posted 7 Mar 2019 02:13
  • By brett_a
  • joined 25 May'17 - 6 messages
  • Tennessee, United States
Thank you so much for your help. A minor adjustment to the encoder arm and all is well.
  • Posted 13 Mar 2019 03:09
  • By brett_a
Is the 12 inch switch on the mast ok? It cuts out high speed lift for the last 12 inches of lift to keep it from slamming stops. Also you say P2 is turned on but is it in P1 performance and not P3 or P2.
  • Posted 11 Mar 2019 06:38
  • By popeye
Elwell-Parker ESI500-36
Maxlion FB25EH
Maxlion FB25EH
