No forword or reverse
I have a truck that has an intermittent problem. When parkbrake is released and I try to go forword or reverse, sometimes in seems as brakes are still applied and truck is trying to go but doesn't move. Let it sit for about 30 minutes or so, try it again and then it will move.
I get no codes, I changed and adjusted swithes at brake valve, hydraulic fluid is full.
Any help is greatly appreciated
  • Posted 22 Jul 2009 17:18
  • By bobby_g
  • joined 22 Jul'09 - 2 messages
also check the rod under the floor board that goes through the pedals. sometimes the rod will shift
  • Posted 22 May 2015 11:27
  • By edward_m
  • joined 11 May'15 - 111 messages
Is it 39x truck?
Any fault codes on the display?
  • Posted 29 May 2014 18:45
  • By Karait
  • joined 21 Jun'09 - 355 messages
  • Poland
I know your deepest secret fear...
J.M.
no drive in forward and reverse after first start up.sometime i can feel it trying to move but not.and does not rev at first as well.
found brake valve block leaking replaced still the same.
but if you push down on the rev pedal very slowly it will move but it wont do it in forward.
when it move in rev then the truck will drive around ok.when truck is turn off then go back to it wont drive unless you press down on the rev pedal very slowly.
  • Posted 24 May 2014 18:26
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
dont think same problem as motor fault would not stop hydraulics,unless your not getting boost pressure. any more info, fault codes etc
  • Posted 7 Apr 2011 15:41
  • By comet
  • joined 17 Nov'09 - 19 messages
  • Sounty Durham, United Kingdom
I have an H25 CT (lp) that has no travel or lift / lower. Sounds about like the same problem?
  • Posted 1 Apr 2011 10:43
  • By stephen_v
  • joined 1 Apr'11 - 1 message
  • Virginia, United States
my guess is you have a 39x your problem is with the drive motor brakes not releasing, this is normally caused by driver using emergancy foot brake constantly.the bad news is you will probably need the motor resealing ,not cheap
  • Posted 17 Nov 2009 07:26
  • By comet
