no forward or reverse
Hi and thanks in advance. I have a hyster e65xm2 lift that wont go forward or reverse everythin else works fine. I noticed that the battery symbol is flashing meaning the batts too low or wrong voltage selected. I know the battery has enough juice and i have tried a 36 and 48v battery with out success. Any help would make my day..i mean month as i have been working on this issue for ever!! Thanks
  • Posted 24 Jun 2007 01:40
  • By josh_w
  • joined 24 Jun'07 - 2 messages
  • Arizona, United States
If you are not getting ANY fault code, then check several things. Make sure that the parking brake is released and that the parking brake switch is working correctly.
Disconnect the battery and press the horn button to discharge capacitors and reset the system.
If lever is in neutral, move to forward or reverse and listen for main contactor.
  • Posted 20 Sep 2007 10:23
  • By larry_b
  • joined 20 Sep'07 - 1 message
Hope This Helps,
Doc
has your truck got a monotrol pedal. sticky foot switchs in monotrol pedal give this fault every time.
  • Posted 29 Jun 2007 04:42
  • By kevin_k
Tom? Who's Tom?
  • Posted 27 Jun 2007 13:22
  • By Truck_Tech
  • United States
no fault codes are displayed but i am gonna check that fuse tom thanks for the advice and ill keep ya posted!
  • Posted 25 Jun 2007 12:31
  • By josh_w
Does the display show any fault codes? Have you checked the main traction power fuse? Sometimes the fuse will pass voltage,but fail under a load.
  • Posted 24 Jun 2007 02:25
  • By Truck_Tech
  • United States
