no crank , starts when bypassed
hello all , I have a 7fgcu32 with a no crank issue if someone could Please share the starter circuit diagram I can resolve the issue
here is what I have done : battery is perfect and holds load test , starter is good , starter relay is good , at the starter relay i have battery voltage on 2 legs and ground on 2 (normal) however when applying the key i lose the ground from 1 leg i can watch it go down on a volt meter as though there s a bad contact or short somewhere.. i have also checked the neutral switch in the shift stock and confirmed it works , also confirmed the ground loss is occuring there as well , i am not sure where the wire goes and dont want to just throw parts at it
  • Posted 1 Apr 2025 02:54
  • By david_le
  • joined 1 Apr'25 - 2 messages
I remember there were some problems with the wiring, above the oilfilter there is a bundle of wires, open them up, there should be a connector with 2 wires, the connector is not used but 1 of the wires could be broken.
The connector is between the second and third cylinder sparkplugs.
  • Posted 14 May 2025 06:53
  • By John50
  • joined 7 Sep'19 - 155 messages
  • Netherlands
I guess no one can help!
  • Posted 9 May 2025 23:18
  • By david_le
TCM FHD105Z
Rail King RK330
edition #1290 - 16 July 2026
In this week’s Forkliftaction News , Jungheinrich has taken out top honours at this year’s International Intralogistics and Forklift Truck of the Year Awards (IFOY) and Noblelift USA has launched its 10T capacity “beast” of a forklift... Continue reading
TCM FHD105Z
Rail King RK330
Fishermen in the town of Oostduinkerke on the western tip of Belgium's coast practice a 500-year-old form of shrimp fishing. Known as paardenvisser, the fishermen trawl the shallow waters on Brabant draft horses, pulling funnel-shaped nets to capture the crustaceans.
September 8-9, 2026 - Barcelona, Spain
November 11-12, 2026 - London, United Kingdom
February 8-10, 2027 - Mumbai, India
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
