No Crank No Start
Evening All,
I'm working on a FG25T-14 (Serial Number 589108A). The Truck ran well all day, and the operator came back at lunch time today and the truck wouldnt start. I have no voltage on my signal wire to the starter when I turn the key. I checked and I have 12 volts to my starter relay, haven't checked my relays because they are not labeled, but I do have two that click when I turn the key to start. I can't pull codes due to my dash board lights being in operable. thank you and any other thoughts are welcome.
Thank you!
  • Posted 19 May 2023 06:33
  • Modified 19 May 2023 20:17 by poster
  • By Mechanicsville8
  • joined 11 May'23 - 16 messages
  • Virginia, United States
ok I appreciate it!
  • Posted 20 May 2023 02:48
Did you get it cranking if not first the starter relay l believe is not in the box that you are looking at look by the air cleaner on the weldment down low there should be a relay l believe that is the starter relay see if you are getting voltage on the load side that is the s terminal to the starter also check all fuses does this truck have the kops system installed. Get back to me if you haven't found it.
  • Posted 20 May 2023 02:20
  • By Scott_
  • joined 16 May'21 - 330 messages
Scott
Taylor T520S
Taylor THC500L
JLG launches YouTube University channel McConnellsburg, PA, United States
Taylor T520S
Taylor THC500L
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
