No Codes
Hello. I am looking for some help with a Hyster E60Z G108N09904F forklift. It doesn't move in any direction, the hydraulics work, and there aren't any codes displayed. I have green led lights on the AC master controller & on both motor controllers. Any help would be appreciated
  • Posted 26 Oct 2019 01:41
  • By Brothercane
  • joined 21 Aug'19 - 9 messages
  • Oregon, United States
I Reject Your Reality And Substitute My Own
Thank you fore responding. I checked the monotrol on Friday 10/26 and found that the the pedal wasn't connected to the pontentiometer. I slid the pin back in and everything is working great. Not used to working on electrics, mostly gas, propane, and diesel.
  • Posted 30 Oct 2019 02:16
  • By Brothercane
If you have hydraulics, then you seat switch is working. I would check the monotrol Pedal or Accelerator Pedal Adjustment making sure the switches are working i.e. getting voltage to and from the pedal. Also, check the parking brake switch.
  • Posted 28 Oct 2019 08:05
  • By John_Rogers
  • joined 26 Oct'19 - 5 messages
John Rogers
