NISSAN MUJL02A28LV
We have a Nissan MUJL02A28LV SER#9VOO21 with intermittent or no spark. Where can I find wiring schematics or info on ignition system so I can diagnose and fix problem. It came into shop with fuel and starting issues. We replaced nikki regulator.
  • Posted 21 Dec 2013 02:22
  • By randy_w
  • joined 21 Dec'13 - 6 messages
  • Saskatchewan, Canada
and if no one is in the seat, [naturally] the truck will not drive, check the seat switch and related wires.
  • Posted 29 Jan 2014 11:10
  • Modified 29 Jan 2014 11:11 by poster
The light flashing on the dash is for the operator presence sensor in the seat. It indicates no one in seat.
  • Posted 29 Jan 2014 07:21
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
the f34 code is for a wire down low on the trans case, just about the bottom wire on the truck, gets pulled off if you have a lot of paper or plastic that you run over.
  • Posted 17 Jan 2014 12:08
Had machine running now will not move forward or reverse. connection and power ok to for/rev solenoid on trans. when it is put in gear the neutral light in dash flashes.
  • Posted 17 Jan 2014 07:41
  • By randy_w
vehicle speed sensor malfunction,
check the wire on the trans case for good connection.
  • Posted 8 Jan 2014 10:20
THE CODE DISPLAYED IS F-34
  • Posted 8 Jan 2014 04:12
  • By randy_w
Does it show any codes on dash display??
  • Posted 22 Dec 2013 06:51
  • By meliftman
Liftman
Retired
Elberta, Al.
Toyota 8FGCU25
Flesherton, Ontario, Canada
UN Forklift FBT20NQZ1
RAEDER-VOGEL
Funerals in Spain typically occur within 24 to 48 hours of death, whereas in other European countries they wait one or more weeks. This rapid timeframe is a cultural norm grown from the past need to manage the warm climate without modern embalming.
