Nissan - Hitachi drive control
Can someone please help with drive fault on Hitachi drive control - very slow creep speed then jumps into bypas speed ? - both directions the same, Lift works ok but no smooth drive at speed.
  • Posted 27 Jul 2013 00:58
  • By Reddog
  • joined 23 Feb'09 - 58 messages
  • Wrexham, United Kingdom
Thank you for the advise I will try what you have said but the battery is not 100% so will need to sort that first.hope you can assist further if the above dosnt't resolve the problem.The battery is 36V - 18 cells the logic cards shows 36/48 volt options.
  • Posted 2 Aug 2013 00:39
  • By Reddog
Reddog;
Check capacitor's charge up rate and it's charge voltage when the battery is just connected up to the truck. Meter pos on capacitor's positive terminal and the meter negative on the truck's negative terminal in the power distribution panel. You should see no more then 2/3 battery voltage and the charge up rate (RC time constant) will occure. An example would be if the source voltage were 10 volts, the resistance is 10 k ohms and the capcitance is 50 micro F, the RC time constant is 0-5 seconds. After 1/2 second, the capacitor will be charged up to 63% of 10 volts, or 6-3 volts. After another 1/2 second the capcitor will charge up to another 63% of the remaining voltage of 3.7 volts, leaving the capacitor about 86% charged and so on. Not having the truck's battery voltage prevents me from more detailed information.
  • Posted 2 Aug 2013 00:06
  • By MEngr
  • Missouri, United States
I thought that may be the case - the appears to be a few burn marks on the buzz link bars on contactors were possibly the logic card has shorted on ? - may be cheaper to retrofit ?
  • Posted 1 Aug 2013 17:12
  • By Reddog
I would guess a bad logic card.
  • Posted 1 Aug 2013 03:03
  • By mike_v
  • joined 1 Jul'10 - 190 messages
  • Illinois, United States
mike_retired
Nissan 50 - D371898
No codes present ? - I believe it was actually imported from American so you may recognise the model ? - it just seems to have no torque ? - until it hits bypass contactor ?
  • Posted 29 Jul 2013 17:47
  • By Reddog
Model AND Serial number would be a help.....plus any codes that are showing up on the display.....
  • Posted 27 Jul 2013 01:44
  • By kevin_t
August 31 - September 2, 2025 - Sultanate of Oman, Oman
September 9-11, 2025 - Birmingham, United Kingdom
Dallas/Ft Worth, United States
Olathe, KS, United States
Neutron stars, the remnants of supernova explosions, have such extreme density that a tablespoonful of their material would weigh over 1 billion tons on Earth.
edition #1241 - 31 July 2025
CeMAT Australia was held in Sydney last week with a larger than usual contingent of Chinese OEMs. Forkliftaction speaks with a number of them to find out why they are targeting the Australian market, and what they feel needs to be done to be successful here. It’s an interesting insight into a shift in the market which is seeing some of China's largest companies making a move... Continue reading
Hangcha CBD15
China
USD1,600
Taylor TT300
USD98,500
