Nissan Electric
I have Nissan Forklift Model# CWP02L-25S
Can someone help me with error code E-020 TM Brush Wear and tell me what it means?
  • Posted 22 May 2014 03:25
  • Modified 22 May 2014 03:33 by poster
  • By Howard
  • joined 22 May'14 - 5 messages
  • New Hampshire, United States
It is the code that is gievn when the brushes are worn out for the power steer motor or could be a simple as the 2 sensor wires on the motor are grounding out. Also have seen where the connector had the blue powder syndrome ( corrosion ) from being exposed to water or simply moisture in the connector. The motor is simple to remove if you have done this before but if you haven't then pack a lunch. 3 12mm bolts holds the motor to the linear actuator. Be sure to keep up with the coupler. Let us know what you find.
  • Posted 22 May 2014 13:09
  • By RCAV8TOR
  • Alabama, United States
Combilift Ltd
Esie Cortez Esie Cortez
