Nissan CPJ02A-25PV overheating
A prospective customer has a big issue with overheating with this truck. It sounds like the Nissan dealer has replaced everything form the sending unit to the radiator and nothing has alleviated the problem. I would assume that they have check most everything since they have been trying to fix this truck for the last 10 months with no improvement. It is a high cycle application loading trucks however we are in NH which has had a very cold winter.
Is this an inherent problem with this model? If so, what can be done to improve the situation? If not, what could they be missing?
  • Posted 25 Feb 2011 01:17
  • By duodeluxe
  • United States
duodeluxe
MEngr- I'm not familiar with bottom by-pass thermostats- I haven't had to diagnose a cooling problem with a set up like this yet. What's the harm in running this set up without the thermostat?
  • Posted 23 May 2012 23:28
  • Modified 23 May 2012 23:29 by poster
  • By bbforks
MEngr,
I am not that familar with the Nissan, thnaks for the info.
  • Posted 23 May 2012 12:55
  • By rogeriwt
Just wondering if you have checked the adjustment of inching linkage and changed transmission fluid and filter. all info and tips expressed are worth double cecking and make sure Radiator is performing as supposed to as Edward T advised and more than likely you will find your source of trouble. Good Luck!
  • Posted 23 May 2012 12:13
  • By Huckleberry
  • joined 20 Jul'11 - 29 messages
  • Tennessee, United States
rogeriwt;
I do believe you may want to wish to re-think your comment. bbforks suggestion is almost identical to the manufacture's recommendation. It is just missing a few other task which are included in Nissan's procedures to correct this issue.
Removal of the thermostat and running the engine without it, is not a wise procedure to take on a bottom by-pass thermostat. Removal of the thermostat and putting it in a calorimeter to check it's function is the OEM's recommended step to take.
  • Posted 23 May 2012 11:37
  • By MEngr
  • Missouri, United States
Stupid suggestion: have you tried removing the thermostat to see if it changes anything?
  • Posted 23 May 2012 07:23
  • By rogeriwt
If the surroundings affect the temp I believe it would be an air flow issue. If all the usual suspects are OK I would install vents in the hood assy & relocate the muffler (assuming it's in the middle & behind the radiator).
  • Posted 22 May 2012 23:19
  • By bbforks
I have sold an identical Nissan CPJ02A-25PV to a fairly high cycle account that is having the identical overheating problem. The water pump has been replaced, the radiator is clean and the coolant is circulating fine. We have checked everything we can think of and it still runs very hot. It is OK in a wide open area but once it is operating in a confined area, such as truck unloading, it runs super hot.
Any suggestions?
  • Posted 22 May 2012 23:09
  • By duodeluxe
  • United States
duodeluxe
A couple other thoughts -
1. Is engine timing set correctly?
2. Valves set correctly?
3. Does this unit have a cat converter? If so - if its "plugged" could be the issue?
  • Posted 25 Feb 2011 21:18
  • By johnr_j
"Have An Exceptional Day!"
all these are good suggestions, and if none of them pan out, or you have an IR temp gun to check the temps, you may find that trucks this young experience clogging of a percentage of the radiator tubes so that while there is circulation, there is not enough to keep water in the rad long enough for it to cool off. you may also find when you do start with the water pump that while the pump seals are good, the blades on the pump maybe rusted away and not pushing much water.
  • Posted 25 Feb 2011 21:05
  • Modified 25 Feb 2011 21:06 by poster
I would be looking at the transmission fluid and filter screen and make sure the inching is adjusted properly. I have had this problem and figured out that the operator kept "resting" his foot on the inching pedal all day and didn't realize it.
Make sure the fan is turned the right way and you didn't say if the water pump had been replaced or not, I'd start there with a new water pump & thermostat, make sure you bleed the system also of you'll have the same problem again real quick.
  • Posted 25 Feb 2011 11:11
  • By roadtech
I've done the service work on lots of Nissan CPJ and H models with the H20 and H20 II motors and never had a overheating problem, even with dirty radiators. I guess the first step would be to check to see if the radiator is as hot as the motor when it overheats to prove the the coolant is circulating. Sounds like it isn't circulating good due to the thermostat or maybe the head water jackets are plugged. If the head gasket is bad and blowing combustion gases into the water, it will definately have problems.
  • Posted 25 Feb 2011 08:54
Terberg RT223
Terberg YT222
Deborah Baker Deborah Baker
Muncie, IN, United States
