Nissan CPJ02-25V Transmission pressure build up
We just finished installing a new torque converter seal and also replaced the pinion shaft seal. There is now enough air pressure build up in the trans housing to pop the dip stick up and then it spews ATF. We removed the breather on the control valve and there are no restrictions. Any ideas what could be causing this?
  • Posted 6 Feb 2013 08:41
  • By duodeluxe
  • United States
duodeluxe
It turned out to be the dipstick. The rubber around the bottom was worn and not holding the dipstick down. We sapped the dipstick with another truck now this one stays in and the other one pops out.
  • Posted 13 Feb 2013 22:21
  • By duodeluxe
  • United States
duodeluxe
Possibly just a simple trans vent stopped/clogged. Try cleaning it and see what happens.
  • Posted 13 Feb 2013 09:48
  • By RCAV8TOR
  • Alabama, United States
How long does it take for the pressure to build up? Does this happen in neutral as well as in gear? If you are still having the problem and the oil cooler did not help, the problem may be as simple as the filter / screen located under the transmission top cover next to the torque converter. Check to make sure that the screen isnt blocked or full.
  • Posted 12 Feb 2013 01:52
  • By lynn_w
  • joined 29 Jan'09 - 36 messages
  • Colorado, United States
Its not the equipment , its how you use it.
restriction in oil cooler/line.
  • Posted 7 Feb 2013 06:49
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
SMV (Konecranes) 4632CC5
Ice 24INCH-AUTO-SCRUBBER
USD6,396
Muncie, IN, United States
USD6,396
Deborah Baker Deborah Baker
