Nichiyu Electric Forklift
Hi to all,
This Nichiyu forklift, Model : FBA25P-60C-400 cannot move ahead or
reverse,
suspect some cable are lose, disconnected or safety interlocked.
The circuit board Nichiyu PB82-40 look fine.
The hydraulic side are working fine.
Can anyone please provide the wiring diagram or manual.
Many thanks in advance.
  • Posted 8 Sep 2012 00:42
  • Modified 9 Sep 2012 00:32 by poster
  • By jeffrey_m
  • joined 8 Sep'12 - 5 messages
  • Singapore, -
Best regards.
Jeffrey Mok
jeffreymok@pacific.net.sg
Hi Jeffrey
Is the problem solved.
I also had the exact same problem
  • Posted 16 Dec 2024 18:07
  • By ario_alif
  • joined 12 Nov'13 - 36 messages
  • east java, Indonesia
arioalif10@gmail.com
Hey Jeffrey,
I'm glad you could solve it and sharing your repairs.
Kind regards
marcb
  • Posted 25 Sep 2012 00:23
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
Hi marc b,
After replacing 2 nos. TA75902P on PB82-40 circuit board and
1 no. 2SD798 on the Fet Comp. the forklift is working fine
now.
Thanks the the help.
Regards, Jeffrey Mok
  • Posted 24 Sep 2012 16:22
  • By jeffrey_m
  • Singapore, -
Good day marc b,
Thank you for the manual.
The model : FBA25P-60C-400
Nichiyu, Year 1997
Voltage :48V.
Will keep you posted on the outcome.
Best regards,
Jeffrey Mok
  • Posted 19 Sep 2012 18:16
  • By jeffrey_m
  • Singapore, -
hey jeffrey, that's strange that it doesn't give an error. Please control the model again.
kind regards
marcb
  • Posted 19 Sep 2012 17:29
  • By marc_b
  • ANTWERP, Belgium
Thank you marc b for the support,
It a 1997 model and does not have a LCD, only a hour and volt meter, have check the contact for for/rev and it giving a the correct signal to the control board, but no output signal to the for/rev contactor and speed control Mosfet.
Please forward the FB-60 manual to me,
I need it as a reference.
My email : [email address removed]
  • Posted 19 Sep 2012 01:35
  • By jeffrey_m
  • Singapore, -
Best regards.
Jeffrey Mok
hello Jeffrey, doesn't it give an error message when you put in forward and depress the accelerator pedal, are the direction contactors closing? I don't have a manual for an FB(A)-60 but i have one for an FB-60 and also don't know what the diffrence is between those two models.
kind regards
marcb
  • Posted 19 Sep 2012 01:03
  • By marc_b
  • ANTWERP, Belgium
