new battery keeps running down
Can anyone help: I have installed a new Battery and checked all the regular things that usally would drain the battery. Have also installed new ring gear and starter have also checked for open circuit and have found nothing yet.
Have installed a new alternator and went thru all wirring.
  • Posted 20 Nov 2007 21:50
  • Modified 21 Nov 2007 22:46 by poster
  • By Smokey
  • joined 20 Nov'07 - 11 messages
Thank you
dcollins131@knology.net
Thank you that works
  • Posted 21 Dec 2007 22:56
  • By Smokey
Remove 1 cable use multi meter in line with batt and removed cable should read 0 if not keep undoing wire 1 at a time till you find scorce of drain.Replace wires you have removed as you check them so you dont cofuse where they go
  • Posted 12 Dec 2007 21:57
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Aichi RX07B
Maxlion MTF25-60-2WD
