Need troubleshooting
Everytime when i switch the key on the display panel show *Monitor disabled* please help me for this error.. Thanks
  • Posted 11 Nov 2015 19:52
  • By Ouano
  • joined 11 Nov'15 - 4 messages
  • muntinlupa, Philippines
Thank you so much sir chevotaman, and now my unit back to normal operation.. thanks a lot
  • Posted 17 Nov 2015 23:30
  • By Ouano
Check your tilt position switch. Located behind the SS carriage next to tilt cyl. Also could be an issue with load sensor transducer (if equipped) located in the tilt cyl. Both can be checked through access 1 inputs.
*Note: If you are tilted full tips down or full tips up. "monitor disabled" on disp. is normal.
  • Posted 13 Nov 2015 01:46
  • Modified 13 Nov 2015 01:59 by poster
  • By chevotaman
  • joined 28 Feb'14 - 112 messages
It's all just nuts n' bolts.
