We currently have a forklift that has name plate or anything that tells us what brand or anything it is. Have pictures if anyone can help us out. Thanks
Where did you get the lift from? I saw on your pictures that there are some dealer stickers present- have you contacted them? The bigger issue you're going to have is when you need parts- some are dealer protected & therefore only available thru the dealer network. If you strike out finding out the make I'd suggest replacing the lift before you have an issue.
We found a number stamped on the body, it is 526075003 and the numbers on the mast are 8116-4 5-1037 and it also has a rockwell rearend. Any help appreciated.
My email is in my profile- send me some pics- I'll see what I can do
