Need help with transmission
I just obtained a 2FG30 tow motor that had the planetary 3rd member remanufactured. It was installed by the previous owner and now does not shift into forward or reverse. Is this something a manual can help me with or is there an ez fix?
Myron
  • Posted 1 Mar 2012 21:48
  • By zorproducts
  • joined 1 Mar'12 - 1 message
  • Arizona, United States
You need to check the Main, forward and reverse transmission pressures before doing anything else
  • Posted 29 Mar 2012 15:41
  • By charlie_j
  • joined 5 Nov'04 - 46 messages
Take time to do the job right the first time, or you will have to make time to do the job over
