mpb 040
alm 01 what is it replaced tiller card ran than stopped alm 01 again continous flashing please help i dont have zapi handset thanks for your help squidman
  • Posted 29 Mar 2008 11:25
  • Modified 29 Mar 2008 11:45 by poster
  • Discussion started by squidman
  • Rhode Island, United States
also:
Continuous Flashing = BATTERY LOW CONDITION
Battery discharged and requires charging.
TRUCK RESPONSE
Hydraulic lift function disabled.
POSSIBLE CAUSES AND TEST PROCEDURES
* Battery voltage is low.
Charge or replace battery.
* Controller voltage calibration is incorrect.
Install handset. Go to test menu and select Battery
Voltage. Compare tester voltage to voltage measured
by an accurate digital voltmeter between B+
and B terminals. Pull down tiller handle to engage
contactor for this measurement. If these two
voltages are more than 1.5 volts difference, replace
controller.
LOGIC
Controller measures low
battery voltage over multiple checks during
traction or hydraulic operation.
13
  • Posted 10 Jul 2008 13:57
  • Reply by VerticalVicDude
Victor Alvarado
Hello
Whats mounted sem !!!!!
Did you calibrate the forward and backward direction You did only change tiller card.
Switch tiller check The brake did you check
Line contractor check
More info about fault !!!
John.
  • Posted 3 Apr 2008 23:13
  • Reply by genjohn
  • NB, Netherlands
Harrisburg, SD, United States
Ottumwa, IA, United States
Wentzville, MO, United States
Ncn 110TH
Ncn 110TH 2023
Hitachi HX99B
