modify travel speed
can anyone help this old man out? recently received a new lift truck @ work and the darn thing crawls. i can never hook up with our service guys to get this modified. our work schedules don't overlap. i know it can be done but not sure how. i know there is a specific PIN to get me into the option to increase travel speed. can anyone help me out with this? the procedure? any assistance would be greatly appreciated.
  • Posted 25 May 2013 21:42
  • By NeZZ
  • joined 25 May'13 - 2 messages
What if within the parameters menu pressing the horn again doesn't make it able to make changes? Also can I get a copy of that parameters list?
  • Posted 30 Sep 2022 14:51
  • By Tobias_Simon
  • joined 30 Sep'22 - 1 message
sorry about that...done
  • Posted 24 Apr 2019 23:50
  • By ladyforklift
  • joined 24 Apr'19 - 7 messages
bantel@ptd.net
Put your email address in your info.
  • Posted 24 Apr 2019 23:25
  • By Yidneck
  • joined 20 Jan'17 - 110 messages
Dreamt I was fixing a machine, then came the paperwork and it turned into a nightmare.
Does anyone have the parameter list to share for an Toytoa 8HBE30?
Thanks in advance
  • Posted 24 Apr 2019 23:05
  • By ladyforklift
i have tried this and don't have the key option. it does not work, the horn just blows nothing on the screen changes. any idea????
  • Posted 10 Jan 2015 05:38
  • By pauly
  • joined 10 Jan'15 - 1 message
  • Maine, United States
outstanding information. and such a quick reply. thank you.
  • Posted 25 May 2013 22:19
  • By NeZZ
esthernrob@aol.com
Press and hold the horn button while turning on the key (if so equipped) to access Special Truck Modes.
Or...
Enter the Operator-Specific PIN Code followed by the green ON button. (The factory default PIN is 1.)
Continue to hold the horn button while the display (read in the numeric field) scrolls through the following modes:
* H = Hour Meter Readings
* E = Error Codes
* P = Parameters
* Pn = Software / Hardware Versions
Release the horn button when the mode you are seeking is displayed.
PROGRAMMING TRUCK PARAMETERS:
Access the Special Truck Mode just as before.
Release the horn button when P (Parameters) appears on the display and the parameter control icon is illuminated.
Use the thumb lever to scroll up or down to the parameter you wish to change or view, as shown on the chart on the following slide. Release the lever when the parameter you are seeking is shown.
Press the horn button once to gain access to adjustment of the selected parameter. The parameter symbol on the display will now flash.
To change the parameter setting, simply rotate the thumb lever to the desired setting. Then press the horn button to confirm the change. End parameter changes with the red OFF button.
Exit Parameter mode by simply pressing the red OFF button
  • Posted 25 May 2013 22:03
  • By kevin_t
Have an email to post in your profile?????
  • Posted 25 May 2013 21:55
  • By kevin_t
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Lithium Storage
Leading China-based developer and manufacturer of Industrial Lithium Batteries.
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
