Model rrb1/14 Bt reach a15 card dc. 1998 machine
Hi im wondering if anyone can give me some pointers, iv fitted a replacement a5 card from our ahem friends at tvh, (the old card lost side shift function) all parameters have been copied across from the old card with zero stored faults, my latest issue is the battery indicator, I'm aware of the wiring on pins 703/4/5 and 611 i think from memory, all are ok and the battery displays full, however after 5 mins of key on time with zero operation the gauge decreases from full to empty with lift cut out. I know the battery isn't an issue as its brand new and just off charge, no comments on the complete waste of money on both battery and logic when those plus combined scrap value we could have bought a far newer machine but these were the cards dealt, is this a faulty a5 card do people know?
  • Posted 1 Aug 2014 23:16
  • By andy_j
  • joined 16 Aug'12 - 38 messages
  • Uk, United Kingdom
Hi, yes the truck is pre 98, well is 98 exactly, parameter 15 was set at 1, is now set to zero, parameter 9 was and still is set to 100, any conclusions? Apologies on the slow turn around of reply, the customer where its at uses it solely for driver training so doesnt mind the slow lift speed, so no real urgency.
  • Posted 12 Nov 2014 19:26
  • By andy_j
Hi.. sorry fro m my side.. i think this is a old reach truck..before 1998 right..
The parameter 15 should be zero.
and you need to confirm the parameter 09 should be 100.
Please check and confirm..
  • Posted 20 Oct 2014 18:28
  • By gopal_s
  • joined 29 Oct'12 - 156 messages
  • karnataka, India
GOP
Apologies for the delay in response, parameter 15 is a 2 option setting ether 0 or 1. Its currently set to 1.
Regards. Andy.
  • Posted 15 Oct 2014 22:23
  • By andy_j
Hi, no this problem is still pending, i can also add that if i disconnect the battery and reconnect it resets to full, ill check parameter 15 monday and get back, thanks.
  • Posted 27 Sep 2014 18:08
  • By andy_j
Is this problem solved.. or still pending..
Can you check the parameter 15 value should be 100.
  • Posted 27 Sep 2014 17:28
  • By gopal_s
  • karnataka, India
GOP
Forgot to mention, iv changed battery parameters to all available and still the same result.
  • Posted 1 Aug 2014 23:18
  • By andy_j
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
CEO, Robust.AI
