Mitsubishi ignition wiring diagram
Hi, guys.
Looking for ignition wiring diagram or information how to connect ignition distributor to coil (with resistor) on Mitsubishi FG-15 with 4G33 engine. Know, that FG-25 with 4G52 engine has the same ignition system. Have a truck, where some "specialist" disconnect all wiring from ignition. Now, we trying to connect it back to previous state, but am worry to burn module, in case of fault.
Ignition distributor has two cable, coil has positive and negative, plus there is some resistor fixed to coil. Have one positive wire coming from main harness. Any help will be much appreciated.
  • Posted 23 Nov 2010 04:33
  • Discussion started by zygmunt_s
  • Zachodniopomorskie, Poland
Hey guys! Can someone email me the ignition schematics or just tell me what goes where? I have the same issue.
  • Posted 28 Jun 2019 15:06
  • Reply by SteveOrama
I too have a Mitsubishi fc15 [ or is it fg15 ?] lpg forklift s/n F25-57100, with the 4g33 lpg engine, started stopping for no reason, then got harder & harder to start: no spark so replaced coil & dropped the wires, [trying to be careful] I too need a wiring diagram to replace them correctly, & probably a new electronic module ,too.[ seems that they fail often ?] Really would appreciate a copy of diagram & advice where can get parts for these old forklifts. It's in really good nick , & I want to keep it going
  • Posted 9 Jun 2019 18:05
  • Reply by robin_b
New member here and I also need mitsubishi/Cat with 4g63 ignition wiring diagram as well. Coil with resistor. Forklift came here with wires disconnect from coil and resistor is full of rust. My email is on my profile for the diagram.
Please and thank you.
  • Posted 29 Nov 2018 01:19
  • Reply by SMB412
  • Illinois, United States
need wiring diagram for coil fg15 thank you
  • Posted 21 Jan 2016 10:08
  • Reply by daevid_h
basic diagram i see with the resistor shows negative going to distributor
positive side has wire with resistor inline from ign side of keyswitch, and a 2nd wire leading to LP fuel solenoid, if gasoline then goes to fuel solenoid at carb.
  • Posted 14 Nov 2014 00:49
  • Modified 14 Nov 2014 00:50 by poster
  • Reply by swoop223
I,m having same issue with a forklift.are you able to send me the wiring diagram for this set up???snake0427 @ yahoo.com. Thank you in advance
  • Posted 13 Nov 2014 21:43
  • Reply by Forksone
  • Victoria, Australia
You might want to check for doides inside the wire harness on this truck. The resistor is used on the run side of the ign switch only. Good luck.
  • Posted 31 May 2012 10:06
  • Reply by stephen_j
  • Indiana, United States
they won;t allow an email address in this forum. try this
info AT trialspartsusa DOT com
  • Posted 23 May 2012 08:57
  • Reply by Hoss
[email address removed]
  • Posted 23 May 2012 08:56
  • Reply by Hoss
Mail adress ?
  • Posted 23 May 2012 04:49
  • Reply by gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
We are also having a problem with the module burning out. Have a new OEM coil and resistor as well as a new module. But mechanic disconnected everything now we need the wiring diagram for this distributor and coil area. Help would be appreciated. Ours is model FG15 with four cylinder LPG. Thank you.
  • Posted 22 May 2012 04:38
  • Reply by Hoss
Hi, Can you email me your circuit, having a lot of difficulties with burning out ignition module. [email address removed]
  • Posted 1 Dec 2010 14:23
  • Reply by heath_j
  • New South Wales, Australia
Thanks Geurt, but your diagram doesn't shows connection to resistor. Its probably older version with ignition points. If someone have diagram for version with ignitor(electronic module inside distributor) and can share it, i'll be more than happy! My email is in my signature.
  • Posted 23 Nov 2010 07:29
  • Reply by zygmunt_s
hi i have send the wiring in your mail..
regards gc_d
  • Posted 23 Nov 2010 04:59
  • Reply by gc_d
Regards gc_d
Wentzville, MO, United States
Ottumwa, IA, United States
Harrisburg, SD, United States
