Mitsubicshi FBC25N Electric lifter truck
can some one help me with a mitsubishi FBC25N, i can't read code because display no work. i need information about the logic card, as i was reading on manual, after replace the logic card it most be set with forklift mode
Do i need special tools to do so or it can be do with setting (DRS)switch Dignosty, Run ,Setting
  • Posted 19 Sep 2010 01:02
  • By JHpantaleon
  • joined 26 Jun'10 - 13 messages
  • distrito, Dominican Republic
JHP
the truck do not work and i do not have a way to read error code because the display, i have a new logic card to replace but it need to be set with the group 3 that allow to enter the lift truck model then group 1 and goup 2 setting, as the logic card can be use with diferent model. what i am not sure if need special tools like handset or computer software with cable to do so
  • Posted 20 Sep 2010 14:14
  • By JHpantaleon
Usually if the display is not working but the truck is, it is just a faulty display. There are no special tools required, everything can be done using the DRS switch, but you need the information to help you.
  • Posted 19 Sep 2010 03:39
  • By AndyPandy
GemOne
Manitou M50-4
Terberg YT222
GemOne
