missing s70ft f187v
Anyone had #1 miss with good compression,175 lbs.Ive done swapped injectors and run feed from #2 to #1 Also swapped plug,wire.Then swapped#1 and #4 on coil.No change.Sprayed stating fluid around intake.Flow at injector hose.Im thinking intake leak but hate to remove it.
Gm 2.4 propane power sorce.
  • Posted 29 Apr 2008 11:01
  • Discussion started by proshadetree
  • Tennessee, United States
Leak at intake manifold. Replaced gasket and was gone. Swapped all parts from Known good cylinder to test.Also lift was tuned up at first of year.
  • Posted 10 May 2008 04:08
  • Reply by proshadetree
I would guess you already changed the plugs?
  • Posted 9 May 2008 08:46
  • Reply by edward_t
edition #1235 - 19 June 2025
