miss firing
changed spark plugs cleaned lpg intake relaced gas converter found leaking
starts ok idles ok under load every now and then back fires
checked coil packs seem ok
any advice TIA
keith
[email address removed]
  • Posted 3 Dec 2024 19:01
  • By keith_roberts
  • joined 28 May'23 - 10 messages
  • New South Wales, Australia
Typically when it idles ok and backfires under load, it's a sign that one cylinders has poor spark. What resistance reading were you getting from the coil packs? It should be between around 0.15ohm and 2.15ohm. Otherwise it is possible you have a weak or bad spark plug.
I would recommend testing the coil packs and spark plugs, then make sure when reinstalling they are seated properly. Otherwise the issue may be further down the coil wiring.
  • Posted 3 Dec 2024 23:08
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 226 messages
  • Wisconsin, United States
Terberg YT220
SMV (Konecranes) 4545CCX5
Terberg YT220
