MIB board calibration
Having problem calibrating lift pot in the handle. No matter what I do it seems like it is not saving settings since lift control stays jumpy applying full power to lift solenoid valve. Is there any trick to this. Lowering works fine and can be modulated. Range I get is 99 and 99 both direction on MIB board.
  • Posted 29 Jul 2021 03:47
  • By ivan_j
  • joined 16 Feb'11 - 65 messages
ivan.forklift.man@gmail.com
Ensure pot is centered before beginning calibration using ohm meter. Do you have a manual to take you through all the steps?
  • Posted 20 Aug 2021 00:39
  • By Fishmech
  • Virginia, United States
Linde Material Handling
