Manual loss electric parking brake
Anyone know how to losen the electric parking brake manualy
I have electric problem so i need to tow it away
  • Posted 25 Jun 2020 05:09
  • By Mattias
  • joined 23 Jun'20 - 3 messages
  • Sweden
Mp
Beneath the brakepedal (take away the cover with the gaspeddle) you see a small hydr.pipe
going in the part that is fitted against the left side of the drive motor.
If you look at the left side of that part there is a plug, (wrench 19/22)take this away and put in a boult same size as from the load backrest. Turn it in some 1cm/1.5cm.
There are 3 springplates inside that you will have to squeesh together to release the brakes.
  • Posted 1 Jul 2020 06:25
  • Modified 1 Jul 2020 06:25 by poster
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
Can you see 2 holes on top of brake. Bolts would go in there to cage the brakes. Sometimes they put the bolts close to brake, just sitting there but tightened, in case you need to loosen brake. Other models just need to back off 3 bolts holding brake together
  • Posted 30 Jun 2020 11:30
  • By EasiTek
Is the brake assembly on the fron Wheels
can only se the pipe and the bleeder no holes att all
  • Posted 25 Jun 2020 23:26
  • By Mattias
  • Sweden
Mp
Most electric brakes have a bypass in the wire harness that will supply battery voltage directly to release the brake. If not found, there may be two holes in the brake assembly, this is for two bolts that would release brake when tightened. Good Luck
  • Posted 25 Jun 2020 22:17
  • By Fishmech
  • Virginia, United States
