Machine will not run unless choked down.
I have a Nissan CPJ01A15PV that will only run if you place your hand over the air horn and cover approximately 80% of the horn. If you remove your hand it dies. I have checked the distributor vacuum advance with a manual hand vacuum pump. It doesn't leak down which leads me to believe that the diaphragm is good. I have removed the vacuum fuel lock off and replaced it with an electric one. Still no change. The LP converter has been replaced twice. Same result. The carburetor/mixer has been replaced. I can't find any source of a vacuum leak. There is a switch of some type that has a vacuum hose going to it and wires connected to it. I don't know what that switch does but I put the vacuum pump on it and a volt meter and all indications show that it is working and has no torn diaphragm in it. I am at a loss at this point. I would truly appreciate it if somebody could tell me what is wrong with this machine.
  • Posted 3 Aug 2022 07:21
  • By MICHAEL_JONES
  • joined 3 Aug'22 - 3 messages
  • Mississippi, United States
Didn't think of that one yet. Glad you found it.
  • Posted 16 Aug 2022 06:55
  • By meliftman
  • joined 31 Jan'12 - 209 messages
  • Alabama, United States
Liftman
Retired
Elberta, Al.
Governor spring broke.
  • Posted 16 Aug 2022 06:07
  • By grant_c
  • joined 12 Aug'16 - 27 messages
  • Manitoba, Canada
You said you have replaced the mixer but is it working correctly? Looking into the barrel while turning the engine, it should pulsate.
  • Posted 13 Aug 2022 22:19
  • By meliftman
Liftman
Retired
Elberta, Al.
Have you measured engine vacuum at an idle? Or engine exhaust back pressure? Engine timing with a timing light or verified by timing marks? Ive seen restricted exhaust and incorrect timing cause this problem in the past.
  • Posted 13 Aug 2022 11:21
  • Modified 14 Aug 2022 05:55 by poster
  • By BLey
  • joined 31 Jul'20 - 60 messages
I have taken the vacuum lock-off off of it and replaced it with an electric one to try to eliminate that possibility. That didn't change anything.
  • Posted 12 Aug 2022 01:43
  • By MICHAEL_JONES
Does it look like that vacuum switch goes directly to manifold ? then just jump that out and see what happens ? maybe it is defective ?
  • Posted 12 Aug 2022 00:05
  • By stillworkin
  • joined 2 Nov'18 - 96 messages
One component not mentioned is the lock off. If unit has vacuum lock off, it can be causing this issue. Will it run if you remove the air filter?
  • Posted 10 Aug 2022 23:25
  • By meliftman
Liftman
Retired
Elberta, Al.
Yes I did. Everything looks good on compression. Also did cylinder leak-down test. No problems there either.
  • Posted 10 Aug 2022 02:35
  • By MICHAEL_JONES
Have you done a compression test? Low compression can cause the engine to not draw enough fuel to run until choked.
  • Posted 5 Aug 2022 03:36
  • By meliftman
Liftman
Retired
Elberta, Al.
