Machine quit moving forward or rev
HISTORY:Unsure what happened. Machine was parked for months. Batteries kept up and all in good condition. 2.57- 2.58 volts in every cell. Machine was just brought into service from sitting for 3-4 months and just got hydraulics working. So I began to use it while driving it to a few different positons there was a clicking noise (sounded like cards clicking on bicycle spokes) but was running with no issues. Parked to to get off and straighten a load I was about to pick up and it would not move. Wheels are free, hydraulics move but truck will not travel under it own power. VERY ODD. Probably another sticking contactor someplace. Gotta start looking into this.
Solved but need more info. Found a lever by seat (seems to be a brake/ disconnect not being allowed to go down all the way due to a bolt that had fallen down jamming the travel of the mechanism. Does anyone know what this is for. When connected with the limits that were set by the lock nuts it would not allow the brake or disconnect to move far enough. SO I reconnected this and ran bolt all the way out to where it is connected to but. It ties the seat to the brake lever mechanically bonding the two together. However we still have this clicking noise in forward or reverse.
Questions:
1.what could be causing a loud clicking noise in forward or reverse that is associated with speed of the wheels.
2. What is the proper adjustment of the ball joint tie rod that bonds the seat lever with the brake/ disconnect.
  • Posted 19 Jan 2015 01:50
  • Modified 20 Jan 2015 02:06 by poster
  • By jackie_h
  • joined 25 Dec'14 - 7 messages
the "cards in the bicycle spokes" noise is often from the motor armature commutator bars getting raised and larger spaces than designed for between the bars, the noise is from the bouncing of the brushes. this happens if the unit is 'stalled" (not able to turn) more than about 5 seconds with full battery voltage going to the drive motor.
  • Posted 24 Jan 2015 04:48
Late 70's Model. I'll start checking from that point. When it was used every day seemed fine but as old equipment goes letting it sit can be its death. Lots of sticking contactors from the scum/ grease built up where I bought it from. THanks
  • Posted 24 Jan 2015 00:31
  • By jackie_h
I'm gonna take a guess here, but it sound like your neutral safety is jammed (or was) in the safe/no move mode via that that seat brake lever. The clicking you hear should be some hefty relays that send power to the motor. How old is this thing? I'm guessing it could be pretty old as it reminds me of a Yale that I worked on eons ago with a similar setup (relay bank to the right of drivers calf and park brake/travel lockout via the seat.
  • Posted 23 Jan 2015 15:52
  • By Turb0
  • joined 17 Jan'15 - 15 messages
  • British Columbia, Canada
Goldfish are opportunistic feeders that have no stomach and lack that natural "fullness" signal. This means they will eat constantly if food is available, leading to serious health issues such as blocked intestines and obesity from overfeeding.
Cincinnati, OH, United States
Louisville, KY, United States
Crown SX3030TT4250
Toyota 4FD240
