Lubricants and capacities
Preparing to drop oil from both hydraulic tank and transmission for filter replacement but have no literature discussing approximate amount of oils I'll need to refill after filter change, and not clear on type of oil called for the transmission, does somebody have this information?
  • Posted 7 Mar 2015 23:51
  • By SteveOh
  • joined 7 Mar'15 - 2 messages
Pray for Peace while preparing for War through Deeds.......not Words.
Trans: Dexronll - 5 quarts(Book calls for Dexron or M2C-33E-F)
(Book calls for 9.5 qt. but that is with draining the torque converter which isn't done on a fluid change)
Hydraulics: 9 Gallons of AW32 (Book calls for I.S.O. VG32 and 10 gal. but you will have nearly that in the cylinders and lines))
Information should be in the operators manual behind the seat, if it's missing get one ordered and be a hero to your customer Publication #0M03Z-L12G0 This covers L01 & L02's.
  • Posted 13 Mar 2015 13:03
  • Modified 13 Mar 2015 13:17 by poster
  • By roadtech
