LP ISSUES
Looking for older info:
Can someone explain the difference between a conventional Impco Model J regulator, and the Cobra (blue spring) regulator?
  • Posted 28 Jul 2023 20:41
  • By PAUL_BEATTY
  • joined 28 Jul'23 - 1 message
The biggest difference in the model J and the Cobra convertor is the primary pressure valve. The model J had a primary seat that was a blade with a square rubber piece glued to the blade. The Cobra convertor uses a plunger with a rubber plug on the tip of the plunger. It was very typical to experience primary side failures, resulting in high fuel pressure, in the 1,000-2,000 hour range. The Cobra convertors primary fuel pressure valve is much more durable. As for the blue spring vs the orange spring, the blue spring is a 1.5 inches water column to open the secondary pressure and the orange spring opens at 1/2 inch water column.
  • Posted 29 Jul 2023 05:10
  • By nsane
  • joined 2 Jun'05 - 14 messages
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
