lp fuel
I have an old s150a hyster with a f245 continental with impco fuel system. I have to hold my hand over carb to get it running, It is too lean if I choke the air system it runs fine. I have replaced the diaphram in the ca125 carb and the model J. Anyone have a clue?
  • Posted 17 Aug 2008 23:29
  • By wellfred
  • joined 17 Aug'08 - 3 messages
  • Kentucky, United States
its allways the unexpected!
  • Posted 22 Sep 2008 17:25
  • By DaveUK
  • joined 12 May'06 - 44 messages
  • BERKSHIRE, United Kingdom
Who bravely dares must sometimes risk a fall.
believe it or not the problem ended up being a week coil.
  • Posted 20 Sep 2008 04:40
  • By wellfred
yes justinm, good point! when I think about it I have an old syringe that I use with a short length of rubber (can I say that) hose that I use. The syringe is tight enough to hold the vacuum so you can start her up. My dad or was it my granpa? told me about "flat heads and L blocks" no just kidding!
Dave :)
PS We have gone off the subject now guys.....my fault I guess I wonder if Wellfred has fixed it yet.
  • Posted 19 Sep 2008 23:07
  • Modified 19 Sep 2008 23:08 by poster
  • By DaveUK
dont su ck on the tube use a vacuum pump
if the lockoff is bad you might get a mouthful of Liquid Petroleum (ouch)
a flathead is also known as an "L-block"
  • Posted 19 Sep 2008 22:22
  • By justinm
I ain't that good,,, my browser has speeel check... I can tell when I mis-peal something,,, (it gets a red line under it...)
yep,,, my bet is not enough negative air pressure at the carb...
  • Posted 19 Sep 2008 08:19
Hi edward, surprised you are up yet its mid day here! you must be super awake though, your spelling is better than mine (vacuum) Glad you agree, would that be a flat head continental in the Hyster, what we call side valve?
  • Posted 18 Sep 2008 21:27
  • By DaveUK
rhymes with "duck"? can you use "vacuum" as a synonym? and I agree with the idea, maybe bypassing the vff30 vacuum lockoff might work for troubleshooting...
  • Posted 18 Sep 2008 21:03
you could also *** on the vaccum hose from the carb to the filter lock.............see if it starts then. If it does it could be a tired engine producing little - induction pressure under cranking.
*** the oposite to blow........the forum removes that word!
regards D
  • Posted 18 Sep 2008 20:56
  • Modified 18 Sep 2008 20:58 by poster
  • By DaveUK
I am going to assume it has an impco VFF30 vacuum lockout , and a J regulator. Test the pressure coming out of the regulator @ the primary test port. pressures should run @ about 3# depending on atmospheric pressure
  • Posted 13 Sep 2008 15:07
  • By Milehighlynn
  • joined 13 Sep'08 - 3 messages
  • Colorado, United States
Ncn 85TH
Ncn 85TH 2014
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
