lowering too fast
I have a reach truck that's lowering way too fast. Activating the velocity fuse but not all the time, No codes. I turned down the lower speed in the performance menu from 90 to 70 (lowest setting) Any further insight will be much appreciated
  • Posted 22 Nov 2016 07:46
  • By buddy84
  • joined 17 Feb'16 - 12 messages
Hi. Yeah i came right. Proportional valve faulty.
Fault code 474 and 473 popping up now and then ? Do you know what it is ?
  • Posted 28 Nov 2016 13:47
  • By landman
  • joined 23 Nov'16 - 2 messages
  • Waikato, New Zealand
For best results
  • Posted 23 Nov 2016 14:09
  • By buddy84
My issue inded up being a bad proportional lowering solenoid valve. Replaced it, calibrated valve hydraulics and everything was good after that. Which lowering valve did you replace? Keep in mind the calibration procedures must be followed correctly.. Forks tilted up, p1 lowering speed @ 90, 1500lbs minimum.
  • Posted 23 Nov 2016 14:08
  • By buddy84
hi. I have the same problem on a crown rr 5700. did not lower at all. replaced the lowering valve. it lowers now but very fast. the velocity fuse comes in to play and only the free lift comes done. what have you done ?
  • Posted 23 Nov 2016 13:49
  • By landman
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
