It was a bad flow control valve, part number 520-163. The Raymond master technician said in 30 years he has only replaced one of those.
Check your Proportional Valve
It is possible there is a blockage in the flow control valve.
Manual lowering is limited speed wise.
Since the manual lowering does the same thing it seems more like a hydraulic issue than a electrical issue
If it is proportional lift/lower it could also be the potentiometer.
Depending on the model you may need to recalibrate the joystick.
Hi I was wondering if you figured out the issue to this problem I see no one replied and I'm having the same issue with a Yale order picker
