Komatsu FD40ZTU-10:
loss of power like its gelling up
Im working on a model fd40zt-8 with what appears to be a fuel issue. The unit is running in cold weather between 0 and 15 degrees fh lately. The unit will run anywhere from 4-6 hours and then loose power to the point of barley moving. Change out the fuel filter and it will run like a top with full power for another 4-6 hours and have the same problem. There are multiple machines running off the same supply fuel and no other issues. This has continued through a few tanks of fuel now. I removed the fuel level assembly and looked down in the tank. Its clean. Dipped out a sample and it appears to be fine. Its had 7 different fuel filter changes now with 3 different brands of filters being used. When it happened I had the customer loosen and remove the fuel cap and then reinstall it in order to rule out any vacuum being created in the tank and not venting properly. I had the customer loosen the fuel filter the last time it happened and then screw it back up tight again without changing it. When they did this it ran good with full power for about an hour and then had the same issue again. When you remove the fuel filter during the problem time it is completely full of fuel. I removed the line from the filter to the injection pump and blew the line out. I did notice during that time that the banjo fitting on the fuel filter has a washer/gasket to seal it and that there was a tiny portion of the gasket missing, but it seals fine. This is a cummings diesel motor. Has anyone ever run into something similiar or have any suggestions other than what I have done?
  • Posted 14 Feb 2018 12:45
  • Discussion started by al_h
  • Wisconsin, United States
I actually found the problem today. On this cummings motor on the fuel filter inlet line from the tank. Its held on with a banjo fitting, well inside the hollow bolt there is a tiny plastic screen and this was plugged. It did not show this in any of the parts breakdowns. Why it would get better after changing the filter is beyond me. This screen was about the size of a pencil eraser.
  • Posted 16 Feb 2018 15:12
  • Reply by al_h
I would order the Complete Fuel Filter assy 6734-71-6110 which includes the head and primer bulb. The primer bulb can leak over time and you loose prime.
  • Posted 15 Feb 2018 23:25
  • Reply by Jeff
There is nothing worse than a sharp image of a fuzzy concept.
-Ansel Adams
Terberg RT223-4X4
JLG 260MRT
JLG 260MRT 2016
Flesherton, Ontario, Canada
Louisville, KY, United States
Dubuque, IA, United States
Terberg YT182
Hangcha 80XENS
edition #1228 - 1 May 2025
Linda Häkkilä Linda Häkkilä
