Loses Travel
The unit loses travel at times in forward or reverse. Seems like the handle position sensor trips it out, but I switched out the sensor and same results. Sometimes it loses travel immediately upon trying to move, and other times it just stops in the middle of moving.
  • Posted 7 Oct 2015 12:01
  • By DaveSr
  • joined 2 Mar'12 - 53 messages
If the unit does not have a display, Remove the rear cover and look for a small led plugged into the controller. Try to operate the truck and see if the led is flashing a code.
  • Posted 8 Oct 2015 23:34
  • By BREWSKI
I did not see a display. Am I missing something? Where would it be?
  • Posted 8 Oct 2015 09:07
  • By DaveSr
Are you seeing any fault codes on the display?
  • Posted 8 Oct 2015 02:08
  • By BREWSKI
