Loses Travel
The unit loses travel at times in forward or reverse. Seems like the handle position sensor trips it out, but I switched out the sensor and same results. Sometimes it loses travel immediately upon trying to move, and other times it just stops in the middle of moving.
  • Posted 7 Oct 2015 12:01
  • By DaveSr
  • joined 2 Mar'12 - 53 messages
If the unit does not have a display, Remove the rear cover and look for a small led plugged into the controller. Try to operate the truck and see if the led is flashing a code.
  • Posted 8 Oct 2015 23:34
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
I did not see a display. Am I missing something? Where would it be?
  • Posted 8 Oct 2015 09:07
  • By DaveSr
Are you seeing any fault codes on the display?
  • Posted 8 Oct 2015 02:08
  • By BREWSKI
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
