Line contactor tips keep burning up
Even if the battery checks good and both line contactor keeps keep burning up with in a month check out these two items. On the mini mast check the filter screen on the hydraulic manifold for blockage. It can cause the related valve to work harder causing the tips to burn. Dont ask me why it just does.
  • Posted 28 Apr 2021 03:09
  • By Mark_Stokes
  • joined 1 Feb'20 - 11 messages
  • Colorado, United States
well i know you said battery checks out, but did you do a load test? put load on the truck with a meter connected to the battery lift it multiple times if it drops more than more than 3volts you may have a weak battery, i would be watching how quick it recovers to the starting voltage
  • Posted 30 Apr 2021 11:07
  • By jimbony
  • joined 19 Feb'19 - 19 messages
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
SMV (Konecranes) 20-1200B
Maxlion MTF30-45-2WD
October 12-15, 2026 - Detroit, MI, United States
