Linde H40D 394 Plenty of revs but holding back
hi, hope someone can help as I am really stuck with this one. The truck is a H40D 394 model, if you put your foot flat to the floor on the drive pedal, the revs will slowly climb but the truck is very slow. When the pedal is only slightly pressed it is ok. The truck has been plugged into diagnostics and the speed and revs are both set to max, the only thing we did notice was the boost pressure was very low in comparison to another h40d, but after removing the turbo it seems there is nothing wrong with it. The truck has plenty of power, just very slow! It is the same story with the hydraulics, and its much worse when cold to the point it barely moves. Hope someone can help. thanks
  • Posted 3 Apr 2015 01:25
  • By savv
  • joined 15 Dec'12 - 11 messages
  • kent, United Kingdom
Hello Sav, did you ever get to the bottom of this drive fault. I have a similar fault
  • Posted 17 Apr 2018 06:29
  • By GarySW1
  • joined 14 Aug'16 - 11 messages
  • Suffolk, United Kingdom
Check under the floor board and see if the rod for the pedal has started sliding out.it can be tapped in.The truck will also creep when just sitting their running. No codes will come up either.Another thing I have found on 393 is I sometimes have to calibrate the tilt angle sensor. Hope this gets you closer
  • Posted 11 May 2015 12:32
  • By edward_m
  • joined 11 May'15 - 111 messages
  • Posted 11 May 2015 12:31
  • By edward_m
  • By edward_m
GemOne
UN Forklift FD25T-C2JM1
Terberg RT223
Nils Altrogge Nils Altrogge
