hi every body......
i have a linde h30d serial 393..... start ok, but when i depress the directional pedal start to move but slow, if i depress all goes slower, the motor accelerate but the forklift dont move....
i dont have any error code... just when i start the service hourmeter show -999.99.....
i apreciate any idea.....thanks in advance.
Showing items 1 - 15 of 19 results.
hello I have the same problem, could you solve your problem?
I would like to see if you can support me please
Ok, thanks I'll give it a go
Hi Michel, thanks for your reply, do you know which service base I need to be using? Thanks
Hi Keith, I am having this exact same problem, can't plug into the engine board of a 393 (CBHA engine) or a 394 (CBJB engine). Did you ever find out how to overcome it? Many Thanks
I have a problem with my linde software. the linde can box works great.but my vw engine service base VW P-D (1.3.0,LINDE MH-D) WILL NOT WORK ON THE UNIT.this unit has the cbha engine in it.i m using the vw cord # 300 365 2503. the service base vw motor diagnose (2.12,linde mh-d ) works fine with beu engine. am I not doing something right.i have had the software looked at and they say nothing is wrong.can any info would be great.
no way you nite laptop whit cambox
EXIST SOME WAY TO RESET THE SERVICE COUNTER??
WITHOUT THE LINDE CAN BOX OF COURSE....
best ting is laptop on truck
That sounds like the service count down, you cant turn this off on a Linde but you can make it a very long time before it flashes up the service spanner by setting the interval to all the 9's
i dont have any error code, just run too slow....just when start in the display shows -999.999..........
if this sensor is broken then you get error code T248
when I hear this story as I say look at brake or parking brake switch
but find it appear strange that he did not foud message
best regarts michel
Hi Gerardo,
The actual speed sensor is mounted on the top housing above the flywheel between the engine and transmission.
Micky
thanks micky, can you tellme where is this sensor?, i cant find it
thanks
